fuel
Old May 31, 2015 | 04:21 PM
jermont76's Avatar
Default fuel
Hello all, I just acquired a 76 monte w/ an aftermarket gas tank, I am assuming it is the same design as the oem tank. but when filling it burbs fuel back at me, is this a normal thing for this car? or should I start looking for a venting issue? I own a 78 eldo and no fuel filling issues altho the filler neck tube is way shorter and straighter. any help would be great thanks Jer
Old May 31, 2015 | 04:29 PM
plumbob's Avatar
I had a '76 several years ago, but don't recall any burping. I think you're on the right track regarding the venting. I would check for clogged EVAP canister fittings &/or hoses.
Old May 31, 2015 | 05:01 PM
KingWord's Avatar
my 86 dual gas tank c10 done this bad,i noticed the neck was kind of loose so I tightened it up and it helped alot
Slamjunk
Sep 29, 2014 03:56 PM
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
robknight13607
Mar 20, 2013 09:14 AM
MJClemm
Mar 18, 2013 07:10 PM
