Firewall hole for 1/0 Gauge wire.
Old Jun 14, 2010 | 02:28 PM
skidoo6713's Avatar
Default Firewall hole for 1/0 Gauge wire.
Old Jun 14, 2010 | 02:38 PM
skidoo6713's Avatar
FYI, it is a 2006 LT2
Old Jun 14, 2010 | 03:52 PM
theres already a hole under the passenger side carpet, you just gotta feel through and push the wire through, be patient with it, but it will go through
Old Jun 14, 2010 | 05:41 PM
Barovelli's Avatar
I have been on a project to run 4 gauge from the engine compartment to the trunk. I could not wrangle the passage for that major bundle in the passenger footwell.
I went through the passenger fender and in the door wiring grommet. Down behind the minor fuse panel and backward to the trunk.
Pull the back seat cushion off (two 18mm bolts) follow the existing wiring, there are no grommets or other obstructions in the back.
Picture story coming soon..
Old Jun 14, 2010 | 05:55 PM
you couldnt fit the wire through the grommet in the floor? i got mine in there pretty easily and its 4 ga also
Old Jun 14, 2010 | 06:30 PM
Barovelli's Avatar
The rectangular solid rubber block? I could not find any way to breach it. Thought better than to stick a scratch-awl in into it.
I took the path of least resistance
Old Jun 14, 2010 | 07:36 PM
04MonteLS's Avatar
That's where I ran my 2ga wire too. And actually, I have pics of that in my build log if anyone cares to see how I did it.
Old Jun 15, 2010 | 11:12 AM
skidoo6713's Avatar
I ran two runs of 8 Gauge through the door panel with my old setup. But i feel 1/0 Gauge would not be the best wired through a door panel. Any pics would be awesome. I dont see how 1/0 Gauge will fit through that hole.
Old Jun 15, 2010 | 11:15 AM
for the rectangle thing in the floor, i dont think you can go through it because its pretty tight but you have to pull it up and go behind it.
Old Jun 15, 2010 | 09:28 PM
04MonteLS's Avatar
I went through it! It's no walk in the park, make no mistake about it, but it is possible.
