6th Gen ('00-'05): Failed compression test on L67
This was super helpful, thanks.
Wound up getting it all off, pics here: https://imgur.com/a/iVap8lm
There's some graphite from the head gasket left, I circled it in red. I think it was head gasket, just want to get your opinions on it since it's my first time dealing with low compression.
Also this is a little off topic, but I noticed you had red spark plug wires. You mind letting me know which brand you got? Thinking about picking up some red ones.
Cylinder was clean, and spark plugs were all normal. I'll try that test in an hour or so, looking at some parts right now.
Wound up bringing the head to a machine shop. They found the crack pretty fast, only cost $20. Kinda sucks, but oh well, just glad that I can start ordering the parts and getting this **** back together.
Glad you found the problem. Take your time when you're ready to install the parts , if something doesn't seem right double check. And be sure to torque all the bolts especially the intake. And a side note on the wires , compare the price on a good set of wires and they're pretty close. Good luck on your car. We're here if ya need more help.
