exhaust
Old May 9, 2007 | 08:55 AM
alesiter's Avatar
Default exhaust
Has anyone seen these? how do you think they would look on an 01'? In body mount exhaust tips mounted behind the rear wheels on both sides. I saw them at stylinconcepts.com
http://www.stylinconcepts.com/parts..../categoryid/28
Old May 9, 2007 | 09:45 AM
Endo's Avatar
Default RE: exhaust
I have not seen them, but I wonder what the rectangular one would look like in front of the rear wheels, as low as possible (even into the ground effects if possible), like a NASCAR. Could always photoshop it up for you if you send a pic of the car.
Old May 9, 2007 | 10:25 AM
alesiter's Avatar
Default RE: exhaust
So I sent an email to stylin concepts and this is what they told me...
It would take a lot of body work and you will need to check your inlet pipe. Most passenger vehicles have a 2.25” -2.5” exhaust pipe which means you would need to weld a larger pipe just to install this tip. It’s not impossible but it will take a lot of work
Would this be hard?
Old May 10, 2007 | 12:19 AM
04 Intimidator's Avatar
Default RE: exhaust
ORIGINAL: alesiter
Would this be hard?
What did your email say that you sent? If you wanted this added to the monte, you would need to sawzall a hole in the rear quarters and slide these in.
Old May 10, 2007 | 07:10 AM
wiz kidd's Avatar
Default RE: exhaust
i would condisder doing them infront of the tire...you can mount them in there a little better and they wont melt plastic there cuz there's no plastic..
i'd love to see what they look like though
cmb66
Apr 21, 2015 07:13 PM
