evap
Old Jun 6, 2010 | 03:35 AM
02montecarlo's Avatar
Question evap
Hey everyone my engine light came on and it was p0440 the evap n possible causes is faulty gas cap, purge solenoid and clogged canister. I replaced the gas cap but just incase that's not it where is the purge solenoid and canister and how do I check to see if that are bad? Thanks
Old Jun 6, 2010 | 03:36 AM
Oops I forgot to say I have an 02 ss...thanks again
Old Jun 6, 2010 | 06:50 AM
Below are links that contain pictures of the parts
and estimated cost of parts.
http://www.theautopartsshop.com/auto...rge-valve.html
Click 2 view
__________________________________________
File Format: PDF/Adobe Acrobat - Quick View
Apr 1, 2009 ... 48: Removing/Installing EVAP Canister Purge Solenoid (3.8L - VIN 1). Courtesy of GENERAL MOTORS CORP. 2002 Chevrolet Monte Carlo SS ...
ww2.justanswer.com/uploads/ebrock63/2009-04-01_180609_INJ.pdf
______________________________________________
Check back on your thread question/problem & hopefully one of our expert tech member's will post
their opinions/solutions/resolve...
Good Luck...Hope the above infor helped...
Old Jun 8, 2010 | 11:07 PM
Also I had just got my fuel pump done...it went off 3 days after it was replaced...could they have screwed something up in the process?
Old Jun 9, 2010 | 06:25 PM
BuddeOs's Avatar
The canister purge solenoid commonly fixes P-0440, but it could also be due to some random insignificant tiny leak in the system. So if you are like me, you might replace these parts and not solve your problem. Good thing is it does not cause any drive ability issues. I just had my car scanned today to make sure it was the only code up, and I deal w/ it.
Old Jun 9, 2010 | 06:31 PM
Ok I went to the parts store to get a manual..and they didn't have one..I would like to find the purge solenoid since its like the cheapest of the 2 meaning the canister. More than likely its on the same place as yours considering they are only a yr apart but I'm not sure...where is it and is it causing mpg loss like significant loss?
Old Jun 9, 2010 | 07:39 PM
BuddeOs's Avatar
No significant MPG loss at all, and if you look at KidSpace's post right after yours click on the "Quick View" for the PDF/Adobe file. The picture is on the 3rd page. It is a little black canister that is about the size of an old Kodak film canister that has 2 hose hook ups on it + 1 electrical connection. It should be 3 inches above your passenger side front motor mount. You will have to take off the plastic engine cover.
Old Jun 14, 2010 | 06:44 PM
Ok I found my purge solenoid it was right ontop of the engine in front. Anyhow I went to grab it and I just came straight up no resistance..I heard its suppoed to have a locking clip is that true?
Old Jun 16, 2010 | 10:13 AM
Endo's Avatar
My light just came on too (P0455) and I've started by tightening the gas cap. Does anyone know if this fixes it if the light will go off on its own or does it need turned off. Then if I do get it turned off and the gas cap didn't fix it it'll obviously come back on again in a day or so, right?
Old Jun 16, 2010 | 10:26 AM
No it won't turn it off cause the gas cap itself isn't a sensor it has to be erased. N yes if it isn't the gas cap it will come back on..sometimes mine take 3-5 days to return
