Engine light
Old Mar 21, 2012 | 06:50 PM
MONTE2000SS's Avatar
Default Engine light
So today I mash the pedal to get out in traffic and the engine light comes on...hooked up scanner and it says low sensor on 02 sensor ....I don't know the correct way to say it but it wasn't getting proper o2.....so my buddy says his cousin had that problem and it needed new plugs ...like a dummy I put these stupid quad sparks in there could it be them?.?????please help me also I am getting a shinning sound from like alternator or something any help would greatly be appreciated ...thanks again
Old Mar 21, 2012 | 06:56 PM
An o2 sensor is hooked to your exhaust.....you only have 2 of them....If this is on a car...
Theres 4 of them on my silverado....
With a good scanner...it should tell you which one it is.....and swap it out with a new one....
Old Mar 21, 2012 | 06:59 PM
It was a snap on one and it said it wasn't bad it just wasn't
Getting the right amount of o2
Old Mar 21, 2012 | 07:02 PM
A "shineing" sound? not sure what that sound is...but if its comeing from the alternator...More than likely....its the bearings in it going bad....Depending on the milage usage etc....(Amps..high rpms)
Maybe needs to be rebuilt or replaced with a new one....
Maybe someone else will chime in to confirm it....
would like to know what the cure was....
A "shineing" sound? (like grinding crunchy sound) not sure what that sound is...but if its comeing from the alternator...More than likely....its the bearings in it going bad....Depending on the milage usage etc....(Amps..high rpms)
Old Mar 21, 2012 | 07:05 PM
U got me on that 1...but i usually use the new E3 plugs....(never had a problem). you can try swapping them out. (plugs) but i dont believe thats the problem....
If it is...that would be tth first time i ever heard of the plugs effecting an o2 sensor....and throwing a code...
Old Mar 21, 2012 | 07:20 PM
what, you put quad plugs in.......
Old Mar 21, 2012 | 07:29 PM
Yes like a dummy stupid quad and it whining sound sorry damn thing changed what. I wrote.
Old Mar 21, 2012 | 07:30 PM
What are e3
hotrodharley
Nov 15, 2013 11:37 AM
moemusic
Mar 16, 2011 04:26 PM
Mex24x
29
Feb 17, 2010 12:35 PM
gohawk72
Oct 2, 2009 02:14 PM
mikeymontecarlo
May 1, 2008 02:41 PM
