engine code
Old May 21, 2010 | 12:58 PM
02montecarlo's Avatar
Unhappy engine code
My check engine light came on so I checked it...said emission control system. What does it mean?
Old May 21, 2010 | 01:14 PM
What was the code?
Old May 21, 2010 | 01:48 PM
Overdose666's Avatar
bum bum buuuuuuum
Old May 21, 2010 | 04:13 PM
What was the code?
P0440 is the code
Old May 21, 2010 | 10:11 PM
Justin Knight's Avatar
make sure the fuel cap is on tight and the rubber gasket isn't cracked. make sure the filler opening isn't rusted. if those items are good and the light comes back on after clearing it the vent solenoid is very common on gm's. but either way your not hurting your ride if its only a P0440.
Old May 21, 2010 | 10:21 PM
So it should hurt even my mpg..I still wanna get it fixed. I got smog coming soon..damn I hate california's smog laws
Old May 21, 2010 | 11:49 PM
nitehawkjcb's Avatar
Yep, it's either your EVAP vent valve or a bad gas cap. Could also be the EVAP charcoal canister, if newer Montes have them.
Old May 22, 2010 | 01:32 AM
So it wouldn't have anything to do with my fuel pump replacement..just had that done last sat n 2 days later the code popped up? Are either of those an expensive and time comsuming project?
Old May 22, 2010 | 02:00 AM
Ok I just looked @ my gas cap and I seen cracks and breaks in the rubber seal..does that mean more than likely its the cap?
Old May 22, 2010 | 09:39 PM
Probably so.
