eiback or intrax?
which do yall think, eiback or intrax lowering springs for my car? the ones on there now are WAYYYYYYYYYYYYYYYY too stiff and are extremely annoying to me now. so which do yall think i should go with?
thanks
thanks
i just put eibachs on mine and am very satisfied, for only a 1.3 drop its pretty noticable, not to mention the incredible improvment on handling, they do tons of research to make sure those springs work perfectly with our cars, unlike intrax which ive heard nothin about, go with eibach
[align=center]
Intrax 2006-07 Monte Carlo LTZ 3.9l V6[/align][align=center][/align][align=center]
Featured Chevrolet Monte Carlo Parts
Taylor Thunder volt 50 OHM 409 Spiro Pro Race Wires
Eibach Pro-Kit Lowering Springs
Borla Monte Carlo stainless steel exhaust
Precision Monte Carlo Lower Billet Grille
GT Styling Monte Carlo headlight covers
Keystone Monte Carlo Custom brickyard style rear spoiler/wing
Topline Lug Nuts - 7/16 Open End Hex (4 Sets In Stock)
Energy Suspension Hyper-Flex System - Urethane Bushings For Gm Cars
Green Green Air Filter - OEM replacement high flow filter
Jet Performance Products GM Power Control Module
Dynomax GM Dual Exhaust System - Monte Carlo, Grand Prix, Impala
Dynomax Gm 305/350 Camaro Shorty Headers Blackjack
Eibach Eibach Pro-Kit Lowering Springs - Monte Carlo
Intrax Eclipse Camber / Alignment Kit - Single
Power Stop Cross Drilled Brake Rotor - Front Left
SP Performance Cross Drilled and Slotted Brake Rotors - Pair
[URL=http://www.sfxperformance.com/parts/MCG24012.htm][IMG]http://www.sfxperformance.com/images
ORIGINAL: scc24540
thanks
thanks
ORIGINAL: 04MonteLS
what springs do you have on there now? I vote for Eibach, they won't lower your car as much as the intrax but the ride won't be as rough either. Also, what shocks do you have?
could possibly be that when he changed the springs your struts were worn out, but he didn't change those, simple check, push down on the back of your car as hard as you can and let go, if it goes up and down more than once you need new struts...springs could still be good
haha i cant push em down lol its like theres nothing there just welded everything in place. i can push the front down if i try real hard and it snaps back to ride height with no bouncing at all. whats that mean
