dyeing seatbelts
Old Jan 29, 2010 | 04:14 PM
78monteman's Avatar
Default dyeing seatbelts
Does anyone know a good way to dye seatbelts. I have a nice tan set that I want to dye black. Either that or does anyone have a good set of black seat belts for a 78 Monte?
Old Jan 29, 2010 | 04:17 PM
Enzo354's Avatar
STILL SLOW
Try Ryte*sp* dye from walmart, it works on fabrics and plastic, so it should work on that.
Old Jan 29, 2010 | 04:21 PM
SSmokybear's Avatar
Just take ur seatbelts to an aviation upholster and they will change out the belts for you with new material. They are the only certified ones that can "repair" seatbelts.
Old Jan 30, 2010 | 01:05 AM
TheMonteMan's Avatar
i dont know about rit dying them. the seatbelt material is kinda tough. i rit dyed a friends carpet in his monte and it came out suprisingly good. if not try a junkyard or.
http://www.opgi.com/product.asp?topc...yearrange=1978
Old Jan 31, 2010 | 03:50 PM
78monteman's Avatar
I tried the Rit dye on one of the belts and I am not sure if Ilike how it turned out, You can still see a bit of tan in it.
Old Jan 31, 2010 | 05:02 PM
i would just get the new belts for it then.
Barovelli
FWD Tech Guides '95-'07
May 14, 2010 10:01 PM
