dual zone climate control module replacement
Hey Peeps......... 2001 monte carlo
I need to get at the drivers side "dual zone" climate control module. I can reach the the passenger side no problem but the drivers side is a bitch. Do I need to take out the top dash board to get this module out?? If so, do I need to worry about air bags going off? PROBLEM: No control of the drivers side tempature. WIth AC on the drivers side still blows out HOT air. AC is on the passenger side. Thanks |
you can always pull the fuse and disconnect the battery to not worry about the air bags.
