DTC'S ... can a gas tank cause one??.. and Cd Player malfunction..
Old Feb 26, 2008 | 08:41 PM
zk6216's Avatar
Default DTC'S ... can a gas tank cause one??.. and Cd Player malfunction..
Hello again to all,
i own a 97 monte carlo LS 3.1 V6 and the service engine light has come one, now this has happened from times before and i know the codes deal mostly with emssions but ... could a leaking gas tank trip a code?? or is it possible?
Thanks For All Who Reply
Ps...
My cd player in the car sometimes plays the cd's and then most of the time spits them out saying ERR ... i have cleaned the eye but i dunno what could be wrong ?? any ideas thanks
THANK YOU FOR READING =)
Old Feb 26, 2008 | 10:05 PM
bowtietech's Avatar
Default RE: DTC'S ... can a gas tank cause one??.. and Cd Player malfunction..
A leaking fuel tank can cause DTC's to set. DTC P0440 or DTC P0442.
Delco does not recommend cleaning their CD players because of the possibility of scratching the laser lens. One thing that will give you the "ERR" message is too much moisture in the player.
Old Feb 26, 2008 | 10:11 PM
zk6216's Avatar
Is there any possible way to get that mositure out of there??
Old Feb 26, 2008 | 10:50 PM
04 Intimidator's Avatar
Take the cd player out and put it in the house/closetwith a dehumidifier. My Blazer had the same problem, the ERR code went away, but someone stole my CD case. =<
Old Feb 27, 2008 | 08:14 AM
zk6216's Avatar
Thank U Intimatator i must try that out because my window has a crack in it like it does not go up the whole way been like that the guy said for a year so maybe that caused moisture to get in thank YOU =)
mstrmysterious63
Apr 18, 2018 04:46 PM
70monte1
Jun 7, 2012 01:05 AM
stumped
Sep 6, 2011 04:53 PM
Herlsy
Apr 1, 2011 11:11 AM
prodigynius
Sep 4, 2009 01:56 PM
