door sagging
Old Aug 22, 2009 | 12:58 PM
markambear's Avatar
Default door sagging
the pin that holds the door up does not have a retainer ,it's crimped.DO
I have to take the hinge off and cut out the old pin?How do I crimp the new pin?
Old Aug 22, 2009 | 04:20 PM
skylark65's Avatar
what year is your monte?
as for the tryng to fix your old hinge, you are probibly better off calling your local salvage yard(s) and see if they have any in stock... remove & replace your old one, quicker, easyer, and quite often cheeper
Old Aug 22, 2009 | 05:56 PM
ryan, he posted before, see below, i'm sure you could offer him some help because of the cars you've seen/had and after all the junkyards you've picked over, lol
08-13-2009, 01:12 PM
markambear
New Member
door sagging
I have a '85 monte ,yhat the driver's door is sagging. When the door is closed the latch hits the pin. How can I adjust the door?
Old Aug 22, 2009 | 06:09 PM
skylark65's Avatar
ok, its an '85... still pretty common in salvage yards, not as many after that big scrap metal boom due to the cars being so heavy..... he should still look for a used hinge, or he could google serch a door hinge rebuild kit..... that should come with the pin & any other peices that could get worn out, & it should be pre crimped....
Old Aug 22, 2009 | 06:39 PM
Budsjlm's Avatar
is d have to agree with the remove and replace like ryan said...check out dixie montecarlo..if im not mistaken they are pritty decently prices
Old Aug 23, 2009 | 02:23 PM
TheMonteMan's Avatar
they usually have the kits in the help section at the part store.
Old Aug 23, 2009 | 04:37 PM
markambear's Avatar
I have the new pin and bushing for my '85 .The new pin needs to be crimped also?
03vaderSS
Dec 9, 2014 03:32 PM
03vaderSS
Sep 29, 2014 01:46 PM
pilotknob1964
Nov 8, 2009 09:52 PM
markambear
Aug 18, 2009 11:54 PM
samf03
Jul 30, 2008 12:26 PM
