Directionals Don't Work
Old Jun 17, 2009 | 07:40 PM
Joe Thomas's Avatar
Default Directionals Don't Work
Both the directionals and four ways do not work on a 2004 MC. Does anyone know where the flasher is located?
Thanks
Old Jun 18, 2009 | 01:23 AM
jim fischer's Avatar
check the fuses?
Old Jun 18, 2009 | 06:51 AM
Joe Thomas's Avatar
Jim:
The lights work once in a while so that rules out the fuses. The lights go on and stay on but don't blink.
Old Jun 19, 2009 | 04:18 AM
vincenti's Avatar
do all your bulbs work? sometimes 1 burnt bulb will do weird stuff.
Old Jun 19, 2009 | 09:29 AM
baja216's Avatar
On my old '02 impala I had the same thing happen. On the Impala the 4 way flasher unit also worked with the turn signals. I got it going by hitting the flasher switch several times. I did end up swapping the unit out, it was pretty straight forward, I had to remove the front of the dash and the unit was right there.
I just got my '02 Monte Carlo and I'm not sure if it's the same here but I thought I would pass that along.
Old Jun 19, 2009 | 07:50 PM
dallasishome's Avatar
I had the same problem in an 04 MC electrcian replaced the hazard lights button fixed the problem
Old Jun 20, 2009 | 07:20 PM
jibb3r's Avatar
Yeah it's the same in the MC. Mine does the same thing. The turn signals work about 50% of the time, if I hit the hazard button on/off, they will work again. I've read the flasher is actually part of the hazard switch on the dash. Meaning the whole dash face has to come off to replace it... One day I will replace the flasher...
BlackRainSS
Feb 29, 2012 06:02 PM
Feb 14, 2012 05:02 AM
Dispatcher7168
Aug 8, 2007 06:06 PM
minnie_mouse_3706
24
Apr 23, 2007 06:22 PM
minnie_mouse_3706
Jul 10, 2006 02:55 PM
