Dead short need help 2003
Old Mar 28, 2015 | 01:35 PM
chuckt's Avatar
Default Dead short need help 2003
2003 Chevy Monte Carlo. The battery went dead. Replaced and the new one drained. Here are the symptoms: no start/not even a crank won't jump start. Clicking relays from the fuse panel, dash panel flashing, speaker static.
Here is what I tried:
Disconnected both battery terminals and used test light and discovered dead short. I traced it to the main wiring harness leading into the cab of the car (not the one leading to starter or alternator) I took out all the fuses one at a time and then the relays one at a time and the test light stays on.
How should I proceed and where can I find a complete car wiring diagram? Also, could the ignition be at fault?
Thanks in advance for any ideas.
ChicagoMonteSS
Jun 7, 2012 05:42 PM
kc2kth
Mar 31, 2012 11:16 PM
dustybird3
Apr 19, 2011 09:39 PM
GrandPaDave
Feb 11, 2011 06:36 PM
Scooby doo
Sep 16, 2009 05:29 PM
