Dead battery
Old Jan 8, 2015 | 07:09 AM
avendo's Avatar
Default Dead battery
I have a new battery in the car..didn't drive it yesterday,it got to 0 deg today and when I went to the car the radar detector was beeping low battery..turned the key and nothing...isn't there a control that shuts all power off after some time? why didn't it and the computer or something sucked the battery dead...
Old Jan 8, 2015 | 07:18 AM
Mels SS's Avatar
The computer itself has a timer built in to shut power down to interior lights and devices that the car controls if you added something to the car it may not shut that off.
Old Jan 8, 2015 | 08:14 AM
owens91's Avatar
Or maybe the cold drained the battery since it wasn't driven. Another possible
Old Jan 8, 2015 | 10:14 AM
03SSLE's Avatar
Charge the battery with a charger (not the alternator), check all your cable connections, then buy a battery blanket.
*Make sure the battery isn't frozen prior to charging it.
Old Jan 8, 2015 | 11:00 AM
avendo's Avatar
I get a 2.2 milliamp draw when I put the amp meter across it.,it has been sitting with the battery charger on it all morn.
Old Jan 8, 2015 | 11:04 AM
avendo's Avatar
the radar is plugged in the cig lighter
Old Jan 8, 2015 | 03:14 PM
Un plug the radar detector...
In the cold weather and any draw on the battery will kill it sitting overnite.
I use to work with Michigans largest towing company and we saw a lot from anything from a radar detactor plugged in..To an interior light, trunklight..etc..Little draws kill it in the cold overnight.
Makes sense.
Old Jan 8, 2015 | 05:00 PM
avendo's Avatar
ok its unplugged...
Old Jan 8, 2015 | 05:02 PM
avendo's Avatar
I thought the bcm would shut it off...
Old Jan 9, 2015 | 06:44 AM
avendo's Avatar
it was ok this morn,but it was 24 deg not 0 and radar was unplugged..but its been plugged in for a while.when i start the car up it flashes low battery.
