Cylinder 1 Misfires
Old Jan 15, 2008 | 08:12 AM
zx3adamania's Avatar
Default Cylinder 1 Misfires
So for the last month Ive been putzin around with my 99 3.1L monte carlo. The car has about 210,000 miles on it so its a little over the hill. Ive been doing all the maintenance myself to avoid high costs at a garage. I had a numerous problems that I will try to list all of now. Car overheated, bubbles in the coolant reservoir(blown head gasket), sweet smelling exhaust. Lower intake seal was ruined, coolant mixing in oil (Not going into cylinders, was an external leak), Car ran rough,(cylinder 1 misfiring) and No heat in the car. So this is what i did, I bought about 300 dollars worth of troubleshooting tools(Ohmns meter, Diagnostic DTC code reader, various other manuals and trouble shooting tools). Replaced all the seals (excluding the head gasket) because i went to a dealership at the very beggining and had them do a compression check to see if the head was blown. They said the head was FINE, but it would be likely that it would go,(the car was overheating and had all the symptoms of a blown head before i did maintenance) After i had replaced the lower intake manifold seal and sealed the walls with RTV(the right stuff) I then went about trying to figure out the Misfire. I changed all new spark plugs, calibrated every one at .060, replaced all the wiring, changed the oil and filter, checked the Coil packs, resistance on them as well..Still got a misfire, then changed the Fuel injector,the problem was GONE. After doing a short drive and flushing my Coolant(to put the BLUE DEVIL IN) now the car says i have a misfire again, the Code was CLEARED off the computer, but now its back...And im clueless as to why. I attempted to fix the head gasket but cleaning the coolant out and putting in new 50/50 coolant and ran it from a cold start up just like it said with the Blue devil(the bottle says its guarenteed or your money back, permanent fix, not temp.) So i did that and it did fix the heating problem, i didnt get above 120 degrees and i get HEAT FINALLY! Might be just because for this problem i had to take out the T stat. btw, I have also changed out the T stat twice since the problem, Changed out the water pump, changed out the rubber lines. Exhaust still spitting out alot of smoke and my misfire can be heard through the "Puh puh puh" in the pipe. My only guess would be that because the engine overheated that the Gasket around cylinder one has melted/warped, therefore causing less compression/bad compression and forcing my cylinder not to work. I was hoping that blue devil stuff would work, i did everything it asked but still didnt work, the gap might be too big. IF ANYONE KNOWS WHAT ELSE I COULD POSSIBLY CHECK BEFORE I RIP IT DOWN TO THE HEADS PLEASE LET ME KNOW. I know this is a little lengthy but i dont want to have to keep replying for weeks in order to get all the details out. Ill post the Diagnostic report i did on cylinder one today as well. Any suggestions are welcome. Thank you.
Duncan` 3.1L 99 monte carlo LS
Old Jan 15, 2008 | 08:59 AM
Default RE: Cylinder 1 Misfires
Report#:2
Report Date:1-15-2008 (8:24 AM)
Vehicle Year:1999
Vehicle Make:Chevrolet
Vehicle Model:monte carlo
Vehicle Engine Size:3.1L
Vehicle VIN:
Vehicle License Plate:
Vehicle Mileage:
Stored:
P0301Cylinder 1 Misfire Detected
Pending:
MILON
MisFire MonitorComplete
Fuel System MonitorComplete
Comprehensive Component MonitorComplete
Catalyst MonitorNot Complete
Heated Catalyst MonitorNot Supported
Evaporative System MonitorNot Complete
Secondary Air System MonitorNot Supported
A/C System Refrigerant MonitorNot Supported
Oxygen Sensor MonitorNot Complete
Oxygen Sensor Heater MonitorComplete
EGR System MonitorNot Complete
DTC for which Freeze Frame was StoredP0301
Fuel System 1 StatusOpen Loop
Fuel System 2 StatusNot Supported
Calculated LOAD Value3.14 %
Engine Coolant Temp129.20 °F
Short Term Fuel Trim - Bank 1-0.78 %
Long Term Fuel Trim - Bank 1-0.78 %
Intake Manifold Absolute Pressure11.22 inHg
Engine RPM842 rpm
Vehicle Speed Sensor0.00 mph
Air Flow Rate Mass Air Flow Sensor0.64 lb/min
Absolute Throttle Position0.39 %
Duncan-3.1`L 99 monte carlo ls
Old Jan 15, 2008 | 08:09 PM
sickofsoyo's Avatar
Bump...
I have no clue man, Im an electronics guy.
Old Aug 29, 2008 | 07:27 AM
SQMazda6's Avatar
It seems to be the head. They are alum and the block is Iron so .. That is why it is spewing smoke like a fog machine. Yea I just got another 3400 in the shop for the same Cil 1 the head is not that expencive but it just takes time to replace it. I am sure you got to the bottom of this problem by now but just posting it on the forum for others to find.
Thanks
Old Aug 29, 2008 | 08:00 PM
rysZ34's Avatar
really with the 3.1 and 3.4 liters if you're going to replace intake gaskets you should replace head gaskets whether it needs it or not. As far as the cylinder misfire, double and triple check and make sure coolant isn't getting into the cylinder. Mazda6, correct me if I'm off, I'm no mechanic. lol. )
Tiggy26
Jan 20, 2015 09:14 PM
05montecarloyo
Aug 8, 2012 07:02 PM
whitemonte
May 28, 2012 10:35 AM
raikel.conerly
Jul 13, 2009 07:38 PM
