Coolant System
Old Jan 17, 2009 | 10:17 AM
mtc7's Avatar
Default Coolant System
What is the easiest way to bleed air out of the coolant system? And is it ok to add green antifreeze to the red antifreeze?
99 monte carlo z34
Old Jan 17, 2009 | 06:47 PM
kweef's Avatar
Default RE: Coolant System
some anti freezers are compatible others are not...id suggest stickin with the same antifreeze that ur already using unless u plan on completly drainin the system and flushing it...as for bleeding the system there should be some bleed vavles somewhere...i am not sure where they r on a 99 z34
Old Jan 17, 2009 | 09:37 PM
desertstars's Avatar
Don't mix them. Not a good idea. Either flush and change or continue with the same.
michelob
Oct 30, 2014 12:08 PM
roost
Jun 4, 2014 10:16 AM
SpinEm_90
Feb 21, 2011 03:00 PM
GMAK907
Dec 2, 2009 03:31 AM
RudeRooster
Sep 30, 2004 11:49 PM
