Opinion Needed: Cluster dash lights arent working
Old Jan 21, 2016 | 10:28 PM
MCMike's Avatar
Default Cluster dash lights arent working
My dash lights aren't working on my 2006 Monte carlo,I thought the bulbs might of been bad so I had all of them replaced but when reinstalled cluster the dash lights still don't turn on,all my steering wheel,a/c seat belt,check engine light,exc... Work except the back lights in dash that light up my gas,temperature,and speedometer,I checked all connectors and checked the headlight & dimmer switch connections and none look Burt nor is there any loose wires I can't figure it out....does anybody have any info on this or experienced this same issue?
Old May 6, 2016 | 11:17 AM
nittygrittysandblasting's Avatar
Was this resolved??? Having the same issue on my sons '02. Only one wire lights up the test light on the switch. Can't find a dedicated I/P fuse, non are blown on either side of the dash or under hood.
Old May 7, 2016 | 07:11 PM
UPDATE: I disassembled the headlamp/dimmer switch and cleaned all the contact points and regreased it, that has fixed the problem for now
