Opinion Needed: Cluster dash lights arent working
My dash lights aren't working on my 2006 Monte carlo,I thought the bulbs might of been bad so I had all of them replaced but when reinstalled cluster the dash lights still don't turn on,all my steering wheel,a/c seat belt,check engine light,exc... Work except the back lights in dash that light up my gas,temperature,and speedometer,I checked all connectors and checked the headlight & dimmer switch connections and none look Burt nor is there any loose wires I can't figure it out....does anybody have any info on this or experienced this same issue?
