6th Gen ('00-'05): Check engine P0366
Old Jul 20, 2019 | 01:02 PM
DannNL's Avatar
Default Check engine P0366
Anyone know exactly what this is?? I have read it's the camshaft sensor. Than people say crankshaft sensor. And finally of course I read it could be the MAF
i have been have issue where the car will stall after like 10 miles and than take a couple of minutes to start. I think I'm going to change the MAF first . But any advice will help
Old Jul 21, 2019 | 07:40 AM
You can unplug the MAF first to check if its that..
Old Jul 22, 2019 | 12:27 AM
DannNL's Avatar
@wht02monte can I drive okay without that plugged in??
Old Jul 22, 2019 | 08:17 AM
yea it might run a little harsh or possibly wanna die when you stop but its safe to drive it like that.. Just take it easy.
Old Jul 22, 2019 | 10:34 AM
When the MAF fails (like by unplugging it) your car has a fueling table in place to work with the MAP sensor. But don't run this way for a while, just do it for a diagnostic test and then get your MAF cleaned or fixed.
The MAF is really needed to work with oxygen sensors to get your car running correctly. You can foul out a few things if you run without it for a while.
Old Jul 23, 2019 | 06:38 AM
DannNL's Avatar
@ChibiBlackSheep the car died again this morning, but stated right back up. I cleaned the MAF sensor with contact cleaner yesterday. Should I still replace it?
Old Jul 23, 2019 | 09:09 AM
I would only replace it if unplugging it temporarily solved the issue.
If unplugging does not solve the issue, you might need to look elsewhere
Old Jul 23, 2019 | 06:57 PM
DannNL's Avatar
@ChibiBlackSheep I drove with the MAF sensor unplugged on my normal route about 5 miles. The car DID NOT stall as it normally would.
the only weird thing was the RPM jumped to about 4000 and struggled for a quick moment, and check engine light came on P0102 which is MAF sensor of course since it's unplugged.
Should I try driving the 5 miles a couple more times and see if it stalls? If it does not I guess the MAF sensor is bad as it would stall with it plugged in
Old Jul 24, 2019 | 05:49 AM
Yeah this does sound like the MAF, but also your idle shouldn't have jumped like that either. I would remove the throttle body and clean it up, as well as carefully clean the IAC.
Old Jul 26, 2019 | 07:03 PM
DannNL's Avatar
@ChibiBlackSheep changed the MAF. Seems to start and run okay. Haven't had the car stall, but my battery light randomly came on for a second like the car went to stall but didn't. Was still able to drive a second after that happened without turning the car off/on. Any idea why that battery light would throw on like It was in the on position?
