6th Gen ('00-'05): Car Shutting Off
Hey, nobody answers me on here, but I'll ask anyway
..my car keeps idling, RPM meter going up and down at stops, then eventually shuts off. I had a similar issue before and I got my Crankshaft Sensor replaced and Oxygen Sensor replaced. Not the same issue is back. Any idea what it could be this time??
I will try that, but to give you a better gauge lf a possible issue, my Crankshaft Sensor is replaced, Oxygen Sensor replaced, and MAP, & MAF (hopefully) is good, replaced a couple years ago brand new..
I assume no codes? I'll throw out throttle body needs cleaning, throttle position sensor going flakey, air idle control valve needs cleaning if you haven't checked these. I had a similar issue without the dying and took the IAC off and cleaned it and the seat and that helped. Also make sure all harnesses are completely seated.
