7th Gen ('06-'07): Car runs when it feels like it
Old Oct 28, 2015 | 09:26 AM
jazz's Avatar
Default Car runs when it feels like it
I got my alternator changed and fuel pump.. Car runs sometimes.. I have no idea wat the problem is.. When its running.. It runs like nothing is wrong
Old Oct 28, 2015 | 11:28 AM
mandy1700's Avatar
Does it die or stall, or does it just not start? Can you be more specific?
Old Oct 28, 2015 | 11:41 AM
jazz's Avatar
It turns off.. No acceleration... The dash lights and everything still be on.. I only know it's cut off when I can't accelerate anymore... Then it doesn't start anymore.. Just cranks but now the 0606 code came back up so I guess I have to take it to a dealership and deal with the high prices
Old Oct 28, 2015 | 12:28 PM
S.O.G.'s Avatar
Check the PCM fuse
Old Oct 28, 2015 | 02:02 PM
With the P0606 code, you need to check the fuse like stated above, and check all ground wires.
If it keeps happening, you might need to get a new PCM programmed unfortunately. The dealer will charge a ton, so look up other options if you HAVE to go that route.
Old Nov 1, 2015 | 07:35 PM
fatfig's Avatar
i guess that saves you a lot of gas.... take it back to the dealership and get it scan. it will cost 75.00
