car jerks at red lights
Old 03-02-2012 | 11:47 AM
cimber's Avatar
Default car jerks at red lights
After driving on the highway then coming to a red light. While pn the brake. The rpms will jump around. Just a couple hundred. What could it be? Thrre are no vodes on the dash. Thanks!
Old 03-02-2012 | 11:53 AM
Dirty MAF sensor or IAC valve possibly.
Old 03-02-2012 | 04:38 PM
cimber's Avatar
Update:
Changed the oil since. The car was really jerky after I drove it for 20 minutes on a highway. The car was off for 10 minutes after that. I started it back up and within 2 minutes of driving at 40 mph, it was doing it. So its doing it while at a decent rate of speed. The engine light came on too. So im gonna get that scanned tomorrow. Ill let you guys know what comes from this!
Old 03-02-2012 | 04:40 PM
Maybe it's a clogging cat if it is happening at 40. hopefully it's not the torque converter not locking up
Old 03-02-2012 | 06:31 PM
DRuben's Avatar
I think maybe a bad plug/plugs or wires or a vacuum leak...
Old 03-04-2012 | 04:46 PM
cimber's Avatar
I was thinking it might be a bad wire or plugs too. Is there a diagram of the vacuum system for a 2000 mc ss?
Old 03-04-2012 | 07:30 PM
mwjames's Avatar
I'd get the cel checked that should point you In a direction
Old 03-04-2012 | 09:40 PM
DRuben's Avatar
Im not sure of any diagram. I always listen to my exhaust and if it surges or lopes every 4-5 seconds and goes back to normal then its my plugs and/or wires and if it sounds lopey like you have a big cam then its a vacuum leak. Thats just what I go by...
Old 04-04-2012 | 05:39 PM
cimber's Avatar
Alittle update to the on going problem.
I have replaced the fuel filter. And installed a new MAF sensor.
The car runs alot better now. Only thing happening now is when im driving and i rev it up to 2500 and let off the gas. RPMs drop down to 1k and bounce once or twice to 1500. It does not do it when in neutral.
The engine light is on.
Code - p0443
Is that code fixable? If so, how?
Old 04-04-2012 | 06:35 PM
DRuben's Avatar
P0443 - Evaporative Emission Control System Purge Control Valve Circuit
What does that mean?
The Evaporative Emissions System (EVAP) allows fumes from the gas tank to enter the engine to be burned, rather than vented into the atmosphere as an emission. The purge valve solenoid is supplied switched battery voltage. The ECM controls the valve by operating the ground circuit, opening the purge valve at specific times allowing these gasses to enter the engine. The ECM monitors the ground circuit as well, watching for faults. When the purge solenoid isn't activated, the ECM should see a high voltage on the ground circuit. When the solenoid is activated, the ECM should see the ground voltage pulled low, close to zero. If the ECM doesn't see these expected voltages, or senses an open in the circuit, this code is set.
Potential Symptoms
P0443 trouble code symptoms could be just an malfunction indicator lamp (MIL) illumination. There may be no drivability problems at all. But, it's also possible to have a lean condition or a rough running engine if the purge valve is stuck open. Usually though, these symptoms are accompanied by other EVAP codes. Another symptom may be excessive pressure in the gas tank in the form of a "whooshing" sound when the cap is removed, indicating a purge valve that isn't working at all or stuck closed.
Causes
To cause a P0443, there has to be a problem with the purge control CIRCUIT, not necessarily the valve. Usually they are a unit housing the valve and the solenoid as an assembly. Or it could be comprised of a separate solenoid with vacuum lines to a purge valve. That said, it could be any of the following:
  • <LI itxtNodeId="54" itxtHarvested="0">Bad purge solenoid (internal short or open) <LI itxtNodeId="53" itxtHarvested="0">Wiring harness chafing or rubbing another component causing short or open on control circuit <LI itxtNodeId="52" itxtHarvested="0">Connector worn, broken or shorted due to water intrusion
  • Driver circuit inside powertrain control module (PCM) is bad
Possible Solutions
1. Using a scan tool, command the purge solenoid to activate. Listen or feel for a clicking coming from the purge solenoid. It should click once, or on some models it may click repeatedly.
2. If it doesn't click with scan tool activation, unplug the connector and examing the solenoid and connector for damage, water, etc. Then check for battery voltage on the feed wire with the key on. If you have battery voltage, then ground the control side manually using a jumper wire and see if the valve clicks. If it does, then you know the solenoid is working properly but there is a problem with the control circuit. If it doesn't click when you manually ground it, replace the purge solenoid.
3. To check for a problem on the control circuit (if the solenoid tests okay and you have voltage to the solenoid) plug the solenoid back in and remove the control circuit (ground) wire from the ECM connector (If you're unsure how to do this, do not attempt). With the ground wire removed from the ECM, turn the key on and then manually ground the Purge valve control wire. The solenoid should click. If it does, then you know there is no problem with the control wire to the solenoid and there is a problem with the ECM purge solenoid driver circuit in the ECM. You'll need a new ECM. However if it doesn't click, then there must be an open in the wiring between the ECM and and the solenoid. You must find it and repair it.
