7th Gen ('06-'07): A/C Blowing Hot
Old Apr 18, 2024 | 04:24 PM
MikeMcD1973's Avatar
Default A/C Blowing Hot
I can't figure out why my A/C is blowing hot air. The compressor is working because I can tell when the clutch kicks in and hear the change in the motor. I tried putting some freon in it and it did take some(about 1/2 a 1 pound can) but no change at all. I do have a bad fresh air actuator that I haven't replaced yet but do have the new part. Any help would be greatly appreciated.
Old Apr 18, 2024 | 05:32 PM
Are you sure the actuator(s) for the temperature control aren't also broken? They're all the same garbage design - could be stuck on hot.
If the actuators are good - how are the AC pressures?
Old Apr 19, 2024 | 03:28 PM
I actually do not have any gauges to check the pressures. I have another question, if it could possibly be a different actuator, do you recommend that I change the (3) that are the same and the other one that looks different from the others?
Lpnffchick
Sep 13, 2019 08:10 AM
Raider
Jun 18, 2014 11:15 PM
drtatma
Mar 17, 2012 04:50 PM
hatecc
Nov 13, 2007 06:26 PM
