7th Gen ('06-'07): A/C Blowing Hot
I can't figure out why my A/C is blowing hot air. The compressor is working because I can tell when the clutch kicks in and hear the change in the motor. I tried putting some freon in it and it did take some(about 1/2 a 1 pound can) but no change at all. I do have a bad fresh air actuator that I haven't replaced yet but do have the new part. Any help would be greatly appreciated.
I actually do not have any gauges to check the pressures. I have another question, if it could possibly be a different actuator, do you recommend that I change the (3) that are the same and the other one that looks different from the others?
6th Gen ('00-'05): Hot air blowing from passenger side while AC on
Lpnffchick
Sep 13, 2019 08:10 AM
Pam
Feb 23, 2018 12:45 PM
6th Gen ('00-'05): A/C only blows hot air from both sides only
Raider
Jun 18, 2014 11:15 PM
