Brake pedal now soft after a hard stop
Old Sep 11, 2016 | 08:48 PM
ckerdflag's Avatar
Default Brake pedal now soft after a hard stop
I have a '05 LT that just turned 50K miles. I'm not the original owner, but bought it in '07 with 10K miles in great condition and have babied it ever since. I've kept the brakes in good shape and have always had a very firm pedal...until about 3 months ago when I was on a 4-lane going about 70 and had to hit the brakes hard to avoid some traffic which had suddenly slowed. The ABS engaged and the tires chirped a bit, but I got stopped. Ever since, the pedal has been much softer with more travel. It's not horrible, but definitely doesn't have the stopping power it used to.
Any ideas on why the pedal is suddenly softer and how to fix it??
Old Sep 11, 2016 | 09:06 PM
I'm not sure why they would be softer. Any leaks under the car possibly indicating a ruptured line??
Your safety is definitely worth a trip to a reputable shop for a full braking system check.
Old Sep 12, 2016 | 03:26 PM
Smile
Have you checked the Brake Fluid level to see where it is? Make sure it is at the recommended level, don't over fill it. Then pump the brakes some and test it again.
Old Sep 12, 2016 | 08:08 PM
plumbob's Avatar
Soft pedal could be air in the system. You might try bleeding.
Old Sep 13, 2016 | 08:47 AM
This was going to be my suggestion. Maybe just get the whole system flushed if it never was.
