brake light issue
Old Apr 2, 2009 | 02:23 PM
giblet78's Avatar
Default brake light issue
i have 1999 z23 model , i dont have brake lights , but third light, parking and turn signals work, do i have a relay that went bad
Old Apr 2, 2009 | 02:38 PM
Arrow Welcome to the Monte Carlo Family : )
There are two reasons they will stop working. One is the fuse of course, but assuming you have checked this already, the brake light switch under the dash, up on the brake pedal, may have gotten out of adjustment, or is bad. Second; The brake lights are wired through the turn signal switch, and it can go bad, thus you have no brake lights. Try this; Have a friend watch your brake lights while you put your foot on the brake pedal. Press it down firmly, and at the same time move the turn signal arm up & down to see if they come on or flash. You don't have to have the igniton switch on to do this, so if its shorting out, it will make the lights come on at some points between the left & right turn signal positions. If they do come on, then you must replace the turn signal switch. If this isn't the culprit, then get under the dash to see if you have power to the brake light switch, and if its sending power to the brake lights. If it is, then check to make sure you have power at the light bulb sockets, and that you have ground at the sockets also. If you do all of this, it will tell you what the problem is.
I hope. A SpaceWebSearched `post
Good Luck
Old Apr 2, 2009 | 03:49 PM
what's a z23?
Old Apr 9, 2009 | 02:31 AM
1972monte's Avatar
Make sure that your brake light bulbs are good first, in my line of work we see alot of cars coming in with a no rear brake light, issue, but the thrd brake light works fine. im sure that your brake light switch is good because your third brake light is still functioning. Now you may have a problem with your turn signal switch, but maybe now as Im not positive of the wiring of your vehicle. But an easy check, without getting too involved is to simply check for power at your rear brake light plug. Simply remove your bulb and check it with a test light. Im assuming that you know what a test light is and how to use it. If you have power to the socket then you know all your wiring is good. Its also good the check for gound, but in my experience grounds dont go bad that often if the vehicle is taken care of fairly well. good luck.
Old Aug 11, 2009 | 05:26 PM
Colonel32s's Avatar
Default Turn signal/brake light issue
Good Luck
I have determined that the turn signal switch is definitely involved in my loss of brake lights. Now i'm curious if a shade tree mechanic can fix this problem. How difficult is it to get to the switch and how can i safely remove and replace the steering wheel airbag? Any information would be greatly appreciated because i love this car and hate not being able to drive it. Thanks.
matthew41
Jan 25, 2015 11:22 AM
hotrodharley
Nov 15, 2013 11:37 AM
heartbeat
Jan 14, 2012 10:47 PM
matrx10503
RWD Tech Guides '70-'88
Dec 29, 2011 10:33 AM
DaytonMC82
May 19, 2010 09:21 PM
