Brake kit upgrade question.
Old Mar 29, 2023 | 05:35 AM
Originally Posted by Anchorman30
I landed on these EBC Stage 2 brake discs https://www.summitracing.com/parts/ebc-s2kr1157 .
Looks like it's only one pair of rotors/ pad set, not sure if that was intentional or not. At a minimum I'd do pads all around - virtually all of the feel improvement comes from the pads, so replacing them all should be step 1.
Do the discs and calipers need to be the same brand?
No. They aren't the same on virtually any car, even from the factory.
I was considering these Power Stop calipers if that’s the case https://www.summitracing.com/parts/p...arlo/year/2006
I didn't look in detail at the specs, but these don't look like any kind of performance upgrade - they just look like red stock calipers.
There are upgraded caliper options if thats what you're after but you've got to be careful with buying stock replacement pads+rotors first (like the EBC set) as theyre incompatible due to being a larger setup.
Angus63
Sep 19, 2022 08:29 AM
culater365
Jan 14, 2016 06:59 PM
HIxArsenaL
May 31, 2014 02:59 PM
03JGMonte
Jul 1, 2011 12:32 AM
emacmonte
Jun 25, 2010 11:14 PM
