5th Gen ('95-'99): Brake booster
Old Jun 29, 2016 | 04:09 PM
Tina Robison's Avatar
Default Brake booster
Can someone please tell me how to remove the brake booster? Any help would be appreciated.
Old Aug 10, 2016 | 08:35 PM
mr markuSS's Avatar
I did one on a 95 Impala SS,so it should be the same procedure:
First,under the hood,unbolt the master cylinder from the booster,and move it forward carefully a couple of inches.Disconnect the vacuum hose from the booster.
Inside the car,remove the lower dash,and the metal panel behind it,using a 7mm socket. Find the brake pedal,follow it up to where it connects to the booster,it is held in place with a pin and a cotter pin on the end of a fork shaped device. The cotter pin removes from the top. There are 4 13mm (iirc) nuts holding the booster in place,three you can remove using a really long extension bar and socket,the upper right one is a pain,using a socket and short extension and short turns. Once the nuts are off,go under the hood and pull the booster off the firewall and remove. Installation is reversal of these instructions.
The brake pedal pin and cotter pin can be a pain to reinstall,be patient.
Old Aug 11, 2016 | 08:01 AM
owens91's Avatar
It's pretty much what he said ^ I did mine on a 95 lumina pretty much the same its just a lot of tight spots
