Blower motor resistor question
Old Jun 25, 2012 | 08:37 PM
Franks 03SS's Avatar
2011 Monte Of The Year
Originally Posted by twfurst
Frank, on a side note, what exhaust are you running? I really like the way it looks coming out the rear.
Well the tips are just magnaflow 4" tips
And I have "oem" mufflers welded in lol
Old Jun 30, 2012 | 02:11 PM
spork's Avatar
Just replaced the resistor today. Those back screws are a complete nightmare to get at. Definitely need a swivel socket or adapter to make it somewhat easier.
Old Oct 10, 2012 | 08:36 AM
dallas's Avatar
my 2003 monte blower only works on 3 4 5 not on 1 or 2
Old May 24, 2013 | 03:55 PM
pugs76's Avatar
Default I can't figure out those screws either for the "module" type resistor...
twfurst, were you able to figure out what kind of screw it is?
Old May 26, 2013 | 01:03 PM
pugs76's Avatar
there were
Old May 28, 2014 | 09:19 AM
Alex03Monte's Avatar
That's the hottest MC I've seen.
Old Oct 19, 2014 | 11:41 PM
el pachuco's Avatar
Thank you for posting the link.
Old Oct 19, 2014 | 11:45 PM
el pachuco's Avatar
just replaced mine, and boy was it junk! :p
the bolt on the right is hardest to get to, you will have to cut some of the liner and padding to make it easier since its super close to the firewall with very little room to work with. i also had to break some of the plastic around the pins as you can see, that made it so much easier to get to the screw. on the new one you can see they changed the layout a little to have more room on the the screw to the right. you only have to remove the front screw and loosen the 2 back ones, after that the piece can slide out and just replace it with your new one
hope this helps someone, not trying to hijack the thread or anything
Damn lol
Very helpful..........Thank you.
Old Apr 12, 2018 | 12:27 AM
Cbuck85's Avatar
Default Here is an image of the blower motor resistor/module for 2004-2005 Monte Carlo
2004 Monte Carlo blower motor resister
I have yet to figure out how to remove the resistor for my 2004 Monte Carlo. Many of you are posting resistors for 2000-2003 Monte Carlos, but they are not the same.
the 2004 Monte Carlo resistor is held together by 2 rivets or plastic tabs. I’m not sure what tool you would use to remove it.
i have attached a picture of it. Any suggestions or ideas would be helpful. Thanks in advance.
Old May 24, 2018 | 09:44 PM
Bellyisis's Avatar
I brought a new one too just 3 weeks ago nos from eBay. I used this video to see how & what is needed to replace it.
