bleeder valve for coolant system
Old Nov 6, 2011 | 09:56 AM
roost's Avatar
Default bleeder valve for coolant system
hi guys,i have a 2007 monte with a 3.5L and was wondering if it has a bleeder for the coolant system,i could not locate one but maybe i missed it.if it doesn't have one then what is the best way to get air out of system?
Thanks
Old Nov 6, 2011 | 11:19 AM
it's on the bottom of the radiator
Old Nov 6, 2011 | 04:38 PM
03SSLE's Avatar
Ummm...I could be mistaken, but I think the petcock on the bottom of the radiator is to drain the coolant...not air from the system.
I looked at a diagram of the cooling system for an '07 Monte w/3.5L and didn't see an air bleed either. I would think that the location of the surge tank hose would allow for air to escape from the system through it.
Old Nov 7, 2011 | 08:42 AM
You don't have one. It's a new kind of cooling system that is supposed to burp itself of air as you drive it.
Fill it up, drive it a little, fill it up, etc. etc. until you are full.
Old Nov 7, 2011 | 02:35 PM
iMSeRiOuS's Avatar
I know on my monte there is one -_-!!! I have the 3800 series II though
Its under the engine cover towards the drives side.. it's a little gold bolt
Old Jun 4, 2014 | 10:16 AM
oglocs928's Avatar
Default bleeder valve location for cooling system
Where would be the exact location of the bleeder valve on a
2001 Monte Carlo LS 3.4L Cooling System, in order to drain any existing air?
SpinEm_90
Feb 21, 2011 03:00 PM
GMAK907
Dec 2, 2009 03:31 AM
One Dark SS
Apr 15, 2009 05:04 PM
mtc7
Jan 17, 2009 09:37 PM
