Opinion Needed: black smoke out of tail pipes everytime i start it
Old Apr 16, 2014 | 08:29 PM
#1Tucker's Avatar
Angry black smoke out of tail pipes everytime i start it
my monte carlo blows black smoke out of tail pipes everytime i start it and sometimes while driving and i smell it inside the car when i turn it off. and keep in mind i just bought it so when i floor it to see what its got it cuts out like maybe it needs a tune up but my mechanic said it doesn't. It also shakes back and forth while im at stop lights sometimes. PLEASE HELP!
Old Apr 16, 2014 | 08:40 PM
Hello and Welcome to the forum!
Tell us a bit more about your car type, year, engine size etc. Lets see if we can get this figured out.
Old Apr 16, 2014 | 09:06 PM
l67ss's Avatar
Check all vac hoses, fpr, and injectors.
Old Apr 16, 2014 | 09:25 PM
Certainly sounds like its running too rich on fuel.
Old Apr 16, 2014 | 09:52 PM
#1Tucker's Avatar
Its a 2001 monte carloo ss 3.8L v6. What's fpr? And what does it mean to be running too rich on fuel?
Old Apr 16, 2014 | 09:59 PM
Means the engine is injecting to much fuel, likely one of the sensors is not working properly. Do you have a check engine light on?
Old Apr 16, 2014 | 10:52 PM
It could be a Bad O2 sensor but then again you would have a check engine light on... Is it on?
If it is...Take it to your local auto parts and have them run scan.. (Its free) That should give you a good idea whats wrong with it.
It will give you a code ... that will indicate what the problem is.
But with all that black smoke..it will eventually clog the Catalytic converter which will be a whole other issue.
So, I recommend you get it resolved as soon as possible...
Old Apr 16, 2014 | 11:08 PM
l67ss's Avatar
Fpr=fuel pressure regulator
Old Apr 17, 2014 | 06:24 AM
03SSLE's Avatar
If it's black smoke you may have leaky injectors.
If you're mistaking blue smoke for black it's probably worn valve stem seals and/or worn valve guides.
Old Apr 17, 2014 | 09:58 AM
#1Tucker's Avatar
Yes the check engine light is on and what are valve stem seals and guides?
