Bad Gas Mileage
Old Feb 22, 2016 | 12:05 PM
85v6's Avatar
Default Bad Gas Mileage
I have a 1986 Monte Carlo Sport Coupe with a stock 4.3 and a thm350 transmission. I know 4.3s aren't great on gas, but I'm only getting 13 mpg. It has a fresh tuneup, and the catalytic converter is the end of the exhaust. (the rest rusted off, i didnt opt for that)
Why is my mpg so bad? Any help would be appreciated.
Old Feb 22, 2016 | 12:21 PM
Unhappy Sorry 4 poor MPG's Good think the price of gas is down 4 now!
Sorry 2 read that you are getting poor MPG's. Who did the tune up and what did they do...Could the cat still be clogged & restricting the flow of exhaust ?
Check the below link to see if it helps...You are not alone...Good Luck
https://www.google.com/webhp?sourcei...4.3L+GM+Engine
Old Feb 22, 2016 | 12:39 PM
85v6's Avatar
I did the tuneup. All Acdelco parts.
Dist. Cap
Rotor button
Plugs & wires
Oil and filter
I don't think the cat is clogged because the car still performs well. The only thing I've had happen is a small backfire while decelerating from 60 or faster. I assume that means it's running a little rich. I park in the same spot every night and warm the car up for 5 Minutes every morning, and where the exhaust exits, the concrete is a little blacker.
Old Feb 22, 2016 | 12:45 PM
How many miles on your engine ? Has it every been rebuilt ? Valve Job ? Jet's replaced in the Carb ? Are you the 1st owner ?
I hope a member can help you. Check bad on your thread later & see what other member's post. Good Luck
Old Feb 22, 2016 | 01:32 PM
85v6's Avatar
It has 65,000 miles. I'm the 2nd owner, but I don't think it has ever been rebuilt
Old Feb 22, 2016 | 01:42 PM
Thanks for your reply. That's super low miles for the year 4-Sure
https://www.fueleconomy.gov/feg/noframes/2113.shtml
Click above link
Regular Gasoline
18
Combined
16
City
22
Highway
Old Feb 22, 2016 | 02:06 PM
Thumbs up Good Luck on MPG's
I hope that one of our expert tech member's see's your thread & can
post some suggestion for your poor MPG's.
Oh, is your air filter clean ? (I didn't see it on your list)
Until then click the below link I hope you enjoy
1986 Chevrolet (USA) Monte Carlo 4gen Coupe full range specs
