antifreeze leak
Old Dec 15, 2010 | 03:56 PM
mr202monte's Avatar
Default antifreeze leak
i change the waterpump and thermostat and seen antifreeze leakin in the back nea the thermostat
Old Dec 17, 2010 | 06:47 PM
jshladwig's Avatar
did u put a gasket for the thermostat housing if not do so and put some RTV sealant on the one side only and that side would be the side opposite the thermostat. i had the same problem til i put a gasket on the housing. good luck
Old Dec 18, 2010 | 11:40 PM
nitehawkjcb's Avatar
Yep make sure the t-stat gasket is in place correctly, and you may need to use some RTV
Old Dec 20, 2010 | 02:20 PM
mr202monte's Avatar
i did that and still leaking some where under the housing, what could it be
Old Dec 20, 2010 | 10:10 PM
Under the housing is the manifold. Maybe an intake gasket leak.
Decoteaujr
Apr 19, 2012 10:02 PM
mitch520
Apr 19, 2009 08:59 PM
Sir Monte
Feb 20, 2008 08:08 PM
hotrodss24
Dec 24, 2007 09:58 AM
87lsman
Jun 6, 2007 01:56 AM
