answer me this and i will owe you.
Old Feb 3, 2012 | 08:00 PM
forgotten's Avatar
Default almost
almost found a way to do enable the oil psi gauge in the ss-ls cluster swap.
I found the correct socket/signal switch part numbers.
i found the correct wiring into the pcm and socket,
but i need to enable it in the pcm from a (ok/not ok) to (ok/low) setting.
I finally had recieved a email back from hptuners that it doesnt have this capability.
think i could convince a service dept at the local dealer to change it????
Last edited by forgotten; Feb 3, 2012 at 09:06 PM. Reason: answer recieved by another source
Old Feb 3, 2012 | 09:43 PM
mwjames's Avatar
if i were in your position i would call around to the local shops and see what they can do for ya. Shouldn't be to big of a deal for them
Old Feb 4, 2012 | 12:11 AM
there's been a few posts of how to do this here on the forum, i can't find the post atm, but just search around, from what I hear and remember seeing it wasnt too hard.
I'll post the link if I can find it
Old Feb 4, 2012 | 12:23 AM
forgotten's Avatar
k thanks. i dont want to put out all the money and rewire the oil psi socket unless i know i can find a way to adjust the pcm....
Old Feb 4, 2012 | 12:25 AM
forgotten's Avatar
i have someone i grew up with that may have a tech 2..... if i have to ill call him next week.
Old Feb 4, 2012 | 01:01 AM
I'm pretty sure you just need the sender, there was no reprogramming the pcm or wiring to it
rj
Jan 8, 2007 03:29 PM
79Monte
Jan 8, 2007 04:57 AM
04MonteLS
Jun 5, 2005 03:41 PM
