Airbag cut-off switch?
Old Feb 2, 2009 | 06:50 PM
SS454's Avatar
Default Airbag cut-off switch?
Newb here...do any of the 2000-2006 monte's have an passenger airbag cut-off or disable switch?
Thanks
Old Feb 2, 2009 | 08:37 PM
bowtietech's Avatar
Default RE: Airbag cut-off switch?
No.
Old Feb 2, 2009 | 11:22 PM
nemesis's Avatar
2009 Monte Of The Year
i'm not sure if this is the same thing we are talking about, but there 2 airbag disable connectors on each end of the dash side. one is on the driver side and the other on the passenger side. if you open your door and pull out the little fuse box like door on the side of the dash you will see a yellow color plastic connector with an orange color rubber band type on the side of it. on my 04 ss that's what i had to disconnect when taking out the air bag in the steering wheel. i'll post pic if i can find it.
Old Feb 2, 2009 | 11:30 PM
SS454's Avatar
I was wondering if there was a key type switch that would disable the pass. airbag. Need to put a kid in the front seat and wanted to disable the airbag but in regards to the switch, it seems no. Thanks.
Jokers1995
Jul 31, 2012 09:11 AM
smolek37k
Aug 6, 2008 08:36 AM
Jster
Jan 11, 2008 05:30 PM
PCWeber
Mar 11, 2007 10:58 PM
