air blows out defrost only
Old Aug 13, 2009 | 09:12 PM
nankipoo's Avatar
Default air blows out defrost only
1997 LS
I just bought this car and I am fixing various things that need tlc. I charged the A/C and it seems to cool, but it only blows out the defrost vent. Also at the same time it seems to blow warm air out the floor vents. It runs great ,so that means not likley a vac leak, right?
Any ideas , Thanks
Lowell
Old Aug 14, 2009 | 08:47 AM
a vacuum is used to move a flap to direct the air to the different ports of the car, so if you can't direct the air it could be vacuum.
Old Aug 14, 2009 | 09:28 AM
The Popcorn King's Avatar
Remove the glove box ( 4 metal screws and 2 plastic ones on the underside). ONce the GB is out of the way, you will see the vacuum lines there. Turn on your air and go thru all the functions. listen to see if you hear and air leak. If there are no leaks, you might want to check the line under the hood. I made a How-To on fixing the underhood problem.
https://montecarloforum.com/forum/fwd-tech-guides-95-07-62/loss-c-air-under-acceleration-fix-5th-gen-9613/
THat will show you where the lines are.
Also, you might have it disconected at the firewall on either side. Just something else to think about.
Raider
Jun 18, 2014 11:15 PM
tloughrin
Dec 22, 2013 08:47 AM
seawolf18
Apr 3, 2012 10:49 AM
Emnasty600
Jul 2, 2011 09:38 AM
PCWeber
Oct 9, 2008 12:15 PM
