Opinion Needed: After Lower Intake Manifold Gasket
Old Nov 21, 2014 | 10:21 PM
Cruvolo93's Avatar
Default After Lower Intake Manifold Gasket
Hey guys, so after completing the lower intake manifold gasket replacement.. The car will start very hard with a rough idle and whine from the driver side of the engine and then stall out quickly. Spark plugs are in place and everything is hooked back up correctly (so I believe). I just don't understand what would whine from the driver's of the engine and cause it to stall out. This is the 3.4. Please help!
Old Nov 21, 2014 | 10:56 PM
nitehawkjcb's Avatar
Could be the alternator whining, and check for vacuum leaks.
Old Nov 22, 2014 | 05:23 AM
Cruvolo93's Avatar
See, I was thinking that something was locking up the belt at first but I took the belt off and was able to spin all the pulleys except the crank. I just don't know what would be whining from the drivers side
Old Nov 22, 2014 | 01:09 PM
Not sure, the only things I would imagine whining is the alternator and power steering pump, but both of those are on the passenger side.
Old Nov 22, 2014 | 09:26 PM
el pachuco's Avatar
It sounds to me like you have an intake leak. Get a can of WD-40 and start the engine. Spray the WD-40 at the intake sealing area on the engine block and see if it affects the engines performance. It should smooth out or rev up if there is a leak.
slanatra
Sep 18, 2013 11:50 AM
Dylan313
Apr 9, 2013 10:03 PM
Shandley
Feb 1, 2012 08:44 PM
RickCoMatic
Oct 31, 2009 07:18 PM
montecarlomike81
Feb 22, 2008 08:28 PM
