98 heater core replacement
Old Mar 8, 2010 | 11:42 AM
98Z34's Avatar
Default 98 heater core replacement
I got coolant smell in cabin, water sounds on revving up and and drip from heater box vent tube on firewall so I'm pretty sure I got a heater core replacement ahead of me. Two questions came up when I started researching this for my older Monte (I say older 'cause I also got a 03 SS recently and it's a beautiful thing, WOO HOO!!)
Questions -
1. What if anything does A/C have to do with replacing the heater core? My mechanic says A/C system will need evacuated and re-charged. When I told him my A/C isn't working right now anyway he says he can knock that off the list of work to do. WTF? How are the two linked - if at all?
2. Some replacement heater cores on-line specify manual temperature control and some say automatic temperature control. Some others don't specifiy anything at all in regards to temp control. All I have is the standard sliding **** for driver and passenger side heat/cool. Is there some real difference in the heater cores that one kind won't work? Or can I just buy one and start busting my knuckles?
Thanks!
gw
Last edited by 98Z34; Mar 8, 2010 at 12:47 PM. Reason: deleted an extra "recently"
Old Mar 12, 2010 | 02:41 PM
98Z34's Avatar
Default Nobody????
Rats!! Nobody knows this heater core stuff?
Old Mar 14, 2010 | 07:54 PM
skylark65's Avatar
wish i had some info for ya man, but thankfully i've never had to replace mine. all i know is that it lives behind the dash somewhere and its a PITA to get to.
hopefully one of the other 5th genners on here can shed some light on this for ya
Old Mar 15, 2010 | 07:33 AM
98Z34's Avatar
Thanks, Skylark. I thought maybe I was invisible. 'Preciate your response
Old Mar 16, 2010 | 05:50 PM
04FrostSS's Avatar
I actually just replaced the heater core in my 04 SS. I don't know if it is similar to the 98 but I can tell you you will be removing the center counsle, seats, and possibly the carpet. It was located underneath the center of the dash and has maybe 1-2 covers over it. Took me about 2 hours plus some because I steam cleaned the carpet and everything while I had it out.
2003 SS
Sep 24, 2017 08:38 AM
Budsjlm
RWD Tech Guides '70-'88
May 25, 2012 07:14 PM
gottarace
Dec 22, 2011 12:19 AM
1BLACKMONTE
Aug 1, 2011 06:38 PM
LRS
Jan 17, 2011 10:46 AM
