97 Carlo Won't Start.. Need Help Fast!
Old Nov 7, 2011 | 04:02 PM
TSauer09's Avatar
Default 97 Carlo Won't Start.. Need Help Fast!
Okay, so I've got a big problem here and I'm not smart about cars at all... I know the basics and that's about it. This morning I got in my car and it started right up like it usually does. I drove about 30 minutes home while it was raining and I turned my car off and ran inside to get ready for class, when came back out my car would not start. When I turn it on, the stereo, lights, and all that come on but when I try to start it, it just clicks and does nothing. What would be the problem??
Thanks for any help!
Old Nov 7, 2011 | 04:40 PM
Possible dead battery, try to get it jumped.
Did you leave your lights on?
Old Nov 7, 2011 | 04:51 PM
zzapultimate's Avatar
The clicking sounds like an almost drained battery. A jump should fix you right up. Unless you have some issue with your battery not charging..
Old Nov 7, 2011 | 05:36 PM
TSauer09's Avatar
I've tried to jump start it, but it still just clicks. All the lights and everything works fine. I've been told I need a new starter, could this be it and if so, how hard is it to put one on?
Old Nov 7, 2011 | 06:22 PM
Rellsun's Avatar
sometimes if you give the starter a few whacks while someone cranks it will start. but the starter is real easy to replace disconnect electrical connections then the 2 mounting bolts. starter is right in the front by the oil filter.
Old Nov 7, 2011 | 08:23 PM
oneslowmonte's Avatar
I would beware jumping the car, I have heard too many horror stories about the aftereffects on the electrical system, a battery pack seems to be a safer bet.
Selinaacosta95
Jun 20, 2013 08:58 PM
BIZZOY310
Aug 29, 2011 04:25 PM
Mattw.2009
Aug 1, 2010 01:27 PM
04 dale jr supercharged
Apr 27, 2010 10:42 AM
ChevRev34
Feb 24, 2008 01:10 PM
