'96 Monte Carlo. No headlights.
1996 Monte Carlo LS
Noticed that the headlights are receiving no power, hi or lo, and the highbeam indicator is not lighting up. The breaker and fuse under the hood are both good. Fuse in the dash is good as well. Is there anything I'm missing before I try to take the switches out and check those?
Does any one know a good source for wiring diagrams?
Any help is appreciated, thanks.
I'd just pop the dash and start probing the switch plug. The dash on these cars is very easy to remove; you could be up and testing in 1 minute flat.
As for wiring diagrams, I'd buy a service manual if you plan to keep the car a bit. I like the thick GM ones personally.
