96 ls cooling issue
Old Nov 18, 2016 | 10:30 PM
Shawn Smith's Avatar
Default 96 ls cooling issue
Hello, I have a 96 ls. I am fighting the cooling system. I replaced the thermostat and flushed the system. After that I noticed a leak by the thermos stat and heater hose. I know for sure they both are fine, my question is where could the coolant be coming from??
Old Nov 18, 2016 | 10:52 PM
nitehawkjcb's Avatar
I'm not 100% sure it's like a 3800 thermostat, but if so, there's a gasket that goes around the edge of the thermostat and it has to be EXACTLY installed or it will leak.
Old Nov 19, 2016 | 06:10 PM
Thanks. Come to find out it is the intake gasket itself.
Old Nov 19, 2016 | 10:57 PM
Eh, at least you got it figured out. The intake gaskets aren't that hard to do, just gotta take out the rods and keep them in order. Best of luck.
