95 Monte 3.1 Just is not sounding good.[Video]
Hey guys, I'm new and figured maybe someone can watch this and tell me if she' if worth trying to fix. I don't have alot of money and am planning to move with in this month. I need to know if I should cut my losses..
Back story: My dad bought the car for me last year about this time. It was running on 5 of the cylinders. He supposedly pay some 900+ for someone to fix it. It did run a WHOLE lot better when I got it back. He told me the piston was bent and they had to fix that. When I did get it back, it ran fine, but leaks oil like there is no tomorrow. I mean it will leak 4qt's with in 3-4 days if not less. So I was trying to drive it to work and (you will hear it in the vid when i press the gas) I heard this putter noise from under the hood. I pulled over and it died. It would not start after that. The guy that towed it got it started just by trying to turn the key. I have since had someone look at it. They said one of the plugs was not firing because of bad Coil Packs. He wanted to charge me $400 do install the packs plugs and wires +parts. I did it my self and this is the result. It sounds the same and now i believe it is hitting the top of the motor towards the end of the vid. video 2011 09 03 11 39 32 - YouTube Thanks in advance. |
Self Bumb, I need help.
I'm sorry to say but I think your looking at replacing or rebuilding that motor , all in all that motor is on its last leg, sounds almost like the 900 spent to fix it may have just been a bandaid that has started to come loose
Originally Posted by Sezotove
(Post 358807)
(Post 358807)
Back story:
(Post 358807)
(Post 358807)
@Zipper:
The monte is not worth much to me. It was just to commute. I will most likely just junk it and get little to nothing for it :\ As far as how the piston was bent for fixed I have no idea. I took it to a shop and they told me it had no compression. It being bent was just what my dad told me. It may burn a small amount. But it is defiantly leaking. In front of the hose there is a 2ft wide by about 8ft(length of the car) long black streak from the car leaking it on the road. I am almost certain that i did it correctly. I followed the placement correctly on the diagram under the hood for the coils, I think it was like 2,6|3,5|1,4 I have no clue atm im not at the car but I did hook the CP's up properly. Now as far as the CP to the plugs I googled the engine and it come up 1,3,5(back) 2,4,6(front) So naturally I matched them up with he corresponding wire running to the CP Thanks for the advise guys |
Like others pointed out already - it's either misfiring or not firing on probably a couple of cylinders. It's kind of hard to tell sometimes when you are right with the car, so trying to tell over the web is even more challenging. I'd probably do a compression test on all cylinders again to rule out something else blown - valve gone through a piston or possibly a head gasket. If you are leaking oil like you say, it's possible that motor has run dry or dry enough to do some damage and it is most likely not worth fixing again honestly.
