5th Gen ('95-'99): 95 3.1 Liter: Engine turns over then dies.
No, he does not need an OBDII tool. This is a '95 Monte, the only year Monte that didn't have OBDII. If it's anything like my Honda, you need to put a paperclip or a wire in one of those connectors you mentioned. This will activate the check engine light codes. It will blink in a series of short and long flashes. For instance. 3 quick flashes and 4 long flashes would be a code 34. Then you google it.
Hot while sitting still could be a lot of things. Fans not working right, air in the coolant, tstat not working correctly. Regardless, you need to flush and bleed your coolant since it has oil in it.
When I had my 3.1 it would have a hard time starting when it was hot, but that was my MAF sensor's fault. You don't have a MAF on your car though, so it beats me. Check your sensors is about all I can say.
Good luck.
Good luck.
Tiggy26
01-20-2015 10:14 PM
kera356
12-01-2013 06:07 PM
SgtWyatt
03-12-2012 10:44 AM
Muddpupp
10-13-2011 02:00 PM
