6th gen Heater Core
1.Remove the lower left and right dash panels.
2. Remove the two screws holding the rear floor duct adapter and remove the duct.
3. The heater core is located under the intrument panel behind a large plastic cover. Remove the screws around the perimeter of cover and carefully work the cover off.
4. Remove the screws retaining the two coolant pipe clamps.
5. Remove the metal clips where the heater core pipes enter the core, then twist and pull the two pipes out of the core.
6. Remove the screw and the clamp at the bottom center of the heater core and pull the core down and out.
Caution: Have plenty of old towels on the floor to protect the carpet.
Install is the reverse, refill and bleed the coolant
There you go. Strait form the Haynes manual.
I tried replacing my heater core but on the 06 its a real pain. Not as easy as the 6th gen. I just used some heater core stop leak and its been good so far (1 month) and no leak or smell.
The 04 is gonna have plastic rivets that hold the cover together so you have to drill them out. It is a real pain but it's do-able. I would pull the seats and center counsel just to make it easier on yourself. My carpet was soaked and so was the pad so I had to pull it back too.
Also no part's stores had the core in stock I had to have it ordered. When I got it the tubes were facing the wrong way they rotate around to fit the monte.
I didn't know the 04 had those rivets. I didn't mention them in the manual. That's what made me give up on it that and having to take my seats out. You should still have screws that would hold the cover in place left over. Those rivets should only be at a few places.
I replaced my heater core on monday and tuesday. It took a good solid 9 hours. It was nothing like the haynes manual said. I kinda had to learn it on my own. But I could change it again now in about 6 hours, knowing what I know now. I took several pictures with my phone. I'm gonna try to post a HOW-TO on here for the 6th gen cars, cuz the haynes manual is a joke. I think the haynes manual was for a 5th gen monte. If anyone has questions on this topic, feel free to ask, as I have learned a lot from this project
