5th gen battery size question, 75 or 78 series.
Old 12-01-2013 | 02:23 AM
Default 5th gen battery size question, 75 or 78 series.
I need a new battery for my Z34, so I go to walmart.com and look for an el-cheapo battery and I bought a series 75N, I picked it up tonight and thought is this the right one....Yes, I have no idea what size is in the car because I really only drive it during the winter, but it needs a new battery. I looked around online and I see that the 75N and 78N are exact fits on advanceauto.com, the only difference is about an inch in length, the 75 is an inch shorter. In some case, an inch could make a world of difference for some things..... Any help would be great, thanks
Old 12-01-2013 | 03:21 AM
l67ss's Avatar
Look up one for a 2001 s10 blazer, they use batteries with the same measurements. Then grab the recomended one that size
Old 12-01-2013 | 10:56 AM
The real question is:
Which amperage battery would be the right choice!
I prefer between 750 and 800 CCA's mines a 75 series!
Good luck Chris hope it gets you thru the winter...
Need all the amps you can safely run when it dips below 0.
I know from personal experience it gets a weee bit chipper in PA!
especially through the mountainous areas.... Ever been thru the poconos or snow shoe?
I have Plenty of times...Good Luck!
Old 12-01-2013 | 11:04 AM
Thumbs up Hi Chris, below is a Vid 4 U > Hope it helps>Good Luck
Battery Replacement: 1995-1999 Chevrolet Monte Carlo - 1999 ... < Click 4 `Vid (get some popcorn) another great GM design WoW > They sure didn't make it E.Z. 4-Real >LOL
► 1:22► 1:22
www.carcarekiosk.com/.../1999...Monte_Carlo_Z34.../...
Jun 23, 2013
Replace the battery in your 1999 Chevrolet Monte Carlo Z34 3.8L V6 once every 4 years for optimal .
Old 12-01-2013 | 10:46 PM
Thanks for the replies everyone, very much appreciated..
I also sent a PM to another 5th gen owner and got the response I needed..
z34phoenix said... 75 will work fine. I have a optima red top 75 in my car.
Thanks Space for the "how to vid" it looks like a total pita to replace.....
Old 12-01-2013 | 10:58 PM
l67ss's Avatar
naH its not bad to change
Denarius23
09-17-2014 03:18 AM
bumpin96monte
08-01-2012 09:24 PM
golfstud2k4
09-29-2010 04:37 PM
nebstewart07
04-22-2010 09:56 PM
04MonteLS
06-03-2005 07:07 PM
