4t65e Transmission pressure control solenoid
Old May 29, 2008 | 09:27 PM
mrl390's Avatar
Default 4t65e Transmission pressure control solenoid
As some people may know, I have been having some transmission issues lately with slipping and a long delay in between selecting gears. I talked to a guy from 60degreev6.com that was a tech of some sort for GM. He said my problem may be the pressure control solenoid. Im going to do a line pressure test on the transmission to verify that. Has anyone replaced the PCS on their 4T65e? Was it hard? What all was involved?
Old May 31, 2008 | 05:35 AM
bowtietech's Avatar
Default RE: 4t65e Transmission pressure control solenoid
To perform a line pressure test you will need access to a Tech 2 scan tool. The Tech 2 controls the PC solenoid during the pressure test. To change the solenoid the trans. side cover must be removed to expose the valve body. To remove the side cover the left drive axle assembly must be removed and the engine/transmission & cradle assembly must be lowered on the left side to provide the clearance needed to remove the side cover. It is a very labor intensive project!
Old May 31, 2008 | 07:56 AM
mrl390's Avatar
Wow, nothing is easy any more is it
Old May 31, 2008 | 10:58 AM
scc24540's Avatar
unfortunatly matt d00d on these cars NOTHING is easy except driving lol
Old May 31, 2008 | 11:48 AM
mrl390's Avatar
Looks like ill have to give up the car to a mechanic for this job.
Bait
Jul 11, 2024 12:23 AM
tridski
Mar 4, 2010 04:41 PM
mekoku
Feb 27, 2010 10:05 PM
nemesis
Jan 15, 2009 11:00 PM
