3.8L stalls when idling
Old Jan 12, 2014 | 07:04 PM
Jtaylor's Avatar
Default 3.8L stalls when idling
I have a 2005 Monte Carlo 3.8L the car stalls when idling. I did some checking and found that the MAF sensor going bad often causes this problem. So I unplugged the MAF and the car ran just fine. So I replaced the old MAF and the car still would stall. What needs to be done to fix it and can I drive with the MAF unplugged till I can get it fixed. Any advice would be greatly appreciated.
Old Jan 12, 2014 | 07:21 PM
ohara's Avatar
Nothing bad happens. The downside is the PCM has to "lookup" fuel pulsewidth values from a table based on ERPM and TPS (kinda reverting to TBI technology except with more injectors and sequential fire). I think while it doesn't hurt durability or power it does not run as efficiently.
The idle also seems to be higher with MAF disconnected in order to keep it stable.
Old Jan 12, 2014 | 07:22 PM
ohara's Avatar
Oh and Welcome to the Forum
Old Jan 12, 2014 | 07:29 PM
Jtaylor's Avatar
Thank you for the fast reply. I think I am going to take it in tomorrow and have it looked at hopefully nothing major.
Old Jan 12, 2014 | 09:07 PM
JC Colon's Avatar
Welcome to MCF "J" you may want to check and Clean your IAC, Idle Air Control valve. If it is stuck closed or almost closed it could cause the engine to stall at idle while having no effect on drivability.
Kuztom Dreamz
Mar 10, 2011 04:59 PM
Enzo354
17
Feb 9, 2011 08:59 PM
bwill987
Feb 26, 2010 08:27 PM
mattilus2121
Feb 26, 2009 02:33 PM
maclawa
Mar 18, 2006 03:32 PM
