2006 Monte Carlo SS where is the oil pressure sender?
Old Oct 5, 2015 | 01:13 PM
kkritislas's Avatar
Default 2006 Monte Carlo SS where is the oil pressure sender?
Hi,
I have a problem with the oil pressure sender sending out intermittent messages. They come and go by themselves, mostly when the car is hot (temperature gauge is in the middle). I would like to find the oil pressure sender unit, both to check the wiring and possibly, if the wiring is fine, replace the actual sender. The car runs fine, it has nothing in the oil (did an oil change last week along with filter, no shavings in the oil). Car has 197K Km (120K-130K miles). I had a similar problem on a Dodge Mirada, and the sensor was the problem in that case, and the symptoms appear similar.
I have the Haynes manual for this car, but it doesn't show anything. I would like to get the factory service manual, but don't have the $400 it would take to get it.
Kostas
Old Oct 7, 2015 | 02:47 PM
ohara's Avatar
I believe the 3.5 is based off the block used in the 3.4. If that holds true, on the 3.4 the oil pressure sensor is in the front of the engine, just off center (towards the driver side of the car) and under the exhaust manifold.Easy to get to, but you don't have great visibility of it unless you are under the car. It will also require a special socket made specifically for the oil pressure sensor. I hope this helps you out.
Old Oct 8, 2015 | 09:09 AM
kkritislas's Avatar
Hi,
Sorry to mislead you and the rest of the members of the board. The car is a Monte Carlo SS, 5.3L V8. I mis-typed the model, and I cannot figure out how to change the title to read Monte Carls SS.
Kostas
Old Oct 8, 2015 | 10:08 AM
Got it taken care of for you
Old Oct 9, 2015 | 12:56 PM
kkritislas's Avatar
P343:
Thanks for clearing that up for me.
Kostas
Old Oct 10, 2015 | 08:06 PM
ohara's Avatar
Here is a a video of exactly where it is and how to change it
Old Oct 11, 2015 | 03:43 PM
kkritislas's Avatar
Ohara, thanks, that is perfect. I was getting confused when doing searches, some said it was up on the top of the engine, like in this video. Others said it was down near the oil filter, hence my confusion.
Old Oct 12, 2015 | 08:00 PM
ohara's Avatar
Glad I could be of assistance best of luck
