7th Gen ('06-'07): 2006 Monte Carlo SS stops accelerating while I知 driving
Old Mar 30, 2018 | 08:02 PM
2CarMonte's Avatar
Default 2006 Monte Carlo SS stops accelerating while I知 driving
My 2006 Monte Carlo will drive until warm. Then will just stop accelerating. I値l push the gas and it痴 reving just not moving at all. I値l turn the car off for 5 secs (usually in the middle of a busy road). Turn it back on and it値l drive anywhere from one tap of the gas to five minutes. Then it starts again. Changing the trans filter tomorrow. Trying to see if anyone had this problem. Just hoping the trans isn稚 shot
Old Mar 30, 2018 | 09:01 PM
96z34man's Avatar
If the transmission were completely gone, it wouldn't come back to life after one key cycle. I wish I could say what it is.
Old Mar 31, 2018 | 04:22 PM
Can you manually change the gear its in and drive?
Old Apr 1, 2018 | 12:43 AM
2CarMonte's Avatar
Default Update
Changed the trans filter today car runs like it痴 brand new. Thanks for the help and potential help. But to answer your question it doesn稚 have a manual option it would shift good for one acceleration and just stall out ie not move when I press gas. I would turn it off turn it back on get one or two presses of the gas n would stall out again. The trans pan had a thick coat of shavings on the magnet connected to the pan.. wiped the pan with a bit of gasoline changed the filter which was 15 $ at a autozone in Atlanta and put it back on drive it about 20-30 miles didn稚 have a single problem. I bought it of cL last week for 1000 on my mama lol I got a steal. The person I got it from took no care of it it had no oil or trans fluid and needs a wheel alignment and motet mount along with the oil and trans fluid I bought. Wheel alignment 65$ on Groupon Moyer mount 30 $. No interior problems. The dude just got it still has lot temp tag for April 12. Just had to share that with y誕ll.
Old Apr 1, 2018 | 04:48 PM
Smile
Good you got it going again, I was going to suggest checking the CAT. Converter sometimes if they are plugged this will cause similar issues.
Old Apr 4, 2018 | 12:26 PM
coolhand's Avatar
My 2002 did. Cat plugged and it melted a hole in my intake just above the EGR stove pipe.
